H16 Crashing
   1869   2   1
Hi, Houdini keeps crashing on me any time I try to write out of an alembic ROP. I get the following error:
terminate called after throwing an instance of 'Alembic::Util::v7::Exception'
what(): OCompoundProperty::init()
ERROR: EXCEPTION:
Already have a property named: name
There is no “name” attribute on my geo, as I have used Attribute Delete to get rid of all attributes except P and my alembic path.
Has anyone else run into this issue? Any ideas?
I can't upload the scene because the alembic contains a proprietary model, but I might be able to recreate an example scene if necessary.
I just tried writing out a single Sphere to the desktop using the Alembic Output ROP on Houdini 16.0.554. It worked without crashing.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
Submit it as a bug with the test case. SideFX has a strict privacy policy for bug submissions with confidential assets. If that isn't good enough, then try to pare down the file as much as possible.
