Hi there,
I was wondering if i could brainstorm a method here. Attached you can see a pentagonal tiling grid. Each line is a primitive and i want to figure out the best way possible to get any primitive and store it's neigbouring primitives.
You can see in the image attached that primitive 471 has 4 neighbour primitives: 464,509,506,444.
I thought that if i make a list for each primitives 2 point vectors and compare these to a list of all point vectors that i would find duplicate vectors and group these, but then i would also need to know the primitives associated with those vectors, not sure how to do this bit?
If anyone has any suggestions i'd appreciate it.
planning to do this in python as i am more familiar with it
Grouping neigbouring primitives which share the same vertex
2355 2 1- 212A
- 21 posts
- Konstantin Magnus
- 670 posts
If they share a point you could use pointprims:
http://www.sidefx.com/docs/houdini/vex/functions/pointprims [sidefx.com]
What is it you want to achieve in the end?
- tamte
- 8555 posts
