Simple question: I want to make lines like on a ruler where every fifth line is longer than the others, there should be an easy way to do this but I can't seem to find it.
Cheers!
How do I scale every fifth copy in a copy SOP?
1421 3 1- aarondornez
- 25 posts
- merlino3d
- 65 posts
Hi Aaron,
try using a copy sop. In the left branch you just put the line that will be duplicated. On the right branch you should plug the points where the line will be placed. This way you'll have identical copies of the first line. The easiest way you can modify the scale is changing the pscale attribute in the right branch whit something like this:
if(@ptnum%5==0){ f@pscale=2; } else{ f@pscale=1; }
- aarondornez
- 25 posts
- matthias_k
- 483 posts
