Hello guys,
Is there a way to make a matrix for an animated object eg: BOX, and extract orientation from that matrix, and use it to orient another object eg: a LINE. The point of this is to animate the LINE ( which is a static object ) in the same way the BOX is animating
Any help will be appreciated
Cheers!
Matrix orientation using wrangles / vops
2368 4 0- MrReedSmith
- 49 posts
- animatrix_
- 4529 posts
There are many ways to do this but if you don't wanna write code you can use Extract Transform Object.
- tricecold
- 260 posts
everything you ever need is avaliable here
http://www.tokeru.com/cgwiki/index.php?title=HoudiniVex#Example:_Rotation
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
- MrReedSmith
- 49 posts
- hernanllano
- 8 posts
I did a tutorial on that, but since I still learning this stuff too I am not sure if my approach is correct, anyway, it may be helpful for you.
https://vimeo.com/214584753 [vimeo.com]
