$N variable in file cache node not working? - H16
   1649   2   0
Doesn't seem to work - when I switch $F to $N according to manual should render out files sequentially numbered. Instead gives no number so overwrites each frame. Is it broken? Or replaced by other variable?
- Jasper
$N is a local variable of the Geometry ROP. Local variables never work through channel references, and File Cache is an HDA that contains a Geometry ROP. Thus $N does not work in the File Cache.
Thanks jlait!
