I am running H16.0 on a macbook pro running windows 7 with a monitor attached to the HDMI. If I drag Houdini onto the second monitor, all dropdown menus appear on my laptop (first) monitor.
one time, I had a scene open and the dropdowns were appearing in the correct place, so I know it is possible. however, I have no idea what was different about that one time.
macbook HDMI second monitor dropddowns under windoze 7
1621 3 1- ivan
- 83 posts
- cgbeige
- 99 posts
- anon_user_37409885
- 4189 posts
- rvinluan
- 1256 posts
ivan
I have a fix for this issue in the next Houdini release but unfortunately it's too risky to backport to Houdini 16.0.
As a workaround, I believe that if you keep your mouse cursor on your primary screen while Houdini is starting up then that will avoid the issue. Once Houdini has finished launching (i.e. the main window appears) then you can move the mouse to the secondary monitor.
Rob
