HI
I had an issue where I have a custom material, done with material builder and then I saved it
as a HDA. I even checked the save cached code in the asset properties. I also have another HDA inside this material
HDA node. I changed this interior HDA using another instance of it outside my material, and the changes didnt go to the material HDA. Is the “save cached code” the reason why my material HDA dosnt get updates, if their inner HDA:s change? or is this a bug? Once I unchecked the save cached code, the changes went nicely to my material HDA.
- seems that it really works like that. and once you check save cached code, you have to be sure you dont want to change the shader
Material Builder as HDA + save cached code
1522 3 1- kojala
- 24 posts
- Olaf Finkbeiner
- 323 posts
- kojala
- 24 posts
- Olaf Finkbeiner
- 323 posts
Hi Kojala,
yes if you like the features that HDAs give you, use HDAs by all means.
And comming back to your original question. Yes a cached code is fixed, if a sub HDA is included it wont change automatically anymore. You need to recompile the shader…
http://www.sidefx.com/docs/houdini/shade/precompile [www.sidefx.com]
kind regards
Olaf
kind regards
Olaf
