I have a curve with 1203 point , and now i want to resample it to exact 800 point , is there any solution for this ?
i want to use it for polypatch or bridge between two curve , currenty i have lot of error after polypatch/polybridge , because there is difference in point number between two curve.
thanks
Resample curve to exact point number
4993 7 0- vrman
- 39 posts
- sl0throp
- 258 posts
- vrman
- 39 posts
- dedeks2999
- 85 posts
- BabaJ
- 2041 posts
- vrman
- 39 posts
dedeks3000
try disabling segment length toggle
BabaJ
Turn off Maximum Segments and adjust Maximum Length Segment until you get the desired number of Points.
Middle mousing the resample node will give you the feedback to how many points you have.
guys i do that by default! the problem is , i cant get exact point number that i want .
thanks for responds
Edited by vrman - Sept. 30, 2017 12:33:15
- BabaJ
- 2041 posts
- vrman
- 39 posts
