Houdini crashed, where are the auto-saved files located?
52185 14 1-
- bobc4d
- 327 posts
- Cyzor
- 181 posts
Depending or your system, crash auto saves could be in /temp, /tmp or maybe /tmp/houdini_temp/.
There might also be a directory called “backup” in the same location as your Houdini project file.
Specified in the HOUDINI_TEMP_DIR variable using the hconfig utility.
http://www.sidefx.com/docs/houdini/basics/config_env [www.sidefx.com]
http://www.sidefx.com/docs/houdini/commands/pathmap [www.sidefx.com]
- old_school
- 2540 posts
$HOUDINI_TEMP_DIR is where Houdini writes cache files and undo files.
When Houdini crashes it writes to $TEMP. So it's $TEMP you want for crash files and crash logs. Btw, please please try to reproduce the crash and send in a Bug report to support with the steps to recreate the crash, the scene file and the .txt crash log file saved to $TEMP.
For new users the easiest way to see what these variables are set to is to fire up Houdini, open a Textport and type:
You can echo any system environment variable inside Houdini if you wish. When it fires up, it sees all the system environment variables using the hscript unix command. Btw hscript unix works on Windows and is used to access any shell command. Yes windows has a shell including the defaults shipped with Houdini. Several in fact: shell, powershell, bash and if you want to install cygwin. You can access any of these system environment variables in any parameter or code snippet in Houdini btw preceded with a $.
Again open up Houdini and open up a textport then type unix printenv to print all the system variables seen by Houdini (and note in that list is TEMP and HOUDINI_TEMP_DIR):
/ -> echo $HOUDINI_TEMP_DIR /tmp/houdini_temp / -> echo $TEMP /tmp
/ -> unix printenv job=/work/user/job TERM_PROGRAM=Apple_Terminal HOST=mymachine.local TERM=xterm-256color SHELL=/bin/bash HOUDINI_TEMP_DIR=/tmp/houdini_temp CLICOLOR=1 HOUDINI_OS=MacOS TMPDIR=/var/folders/8y/n9vxx_kj1t17b1j5yhf87zl00000gn/T/ H=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources hou10dir=cd /Users/jeff/Library/Preferences/houdini/10.0 sqa=/n/iowa2/tmp/jeff/user/sqa HOUDINI_BUILD_KERNEL=15.6.0 Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.aiBLuTVS7c/Render HOUDINI_BUILD_VERSION=717 HDSO=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/../Libraries TERM_PROGRAM_VERSION=361.1 HT=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/toolkit TERM_SESSION_ID=7A1EDE4D-83F5-4ADB-B803-303F84819980 comp=/work//user/comp previs=/work//user/previs render=/work//user/render HH=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/houdini user=/work//user USER=jeff TEMP=/tmp hj=/Users/jeff/houdini.jeff HSB=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/houdini/sbin HOUDINI_BUILD_PLATFORM=Mac OS X 10.11.6 HIP=/private/tmp vfx=/work//user/vfx char=/work//user/char demos=/work//Demos/demo_repository HOUDINI_MINOR_RELEASE=0 SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.n13VDH4EY3/Listeners __CF_USER_TEXT_ENCODING=0x1F5:0x0:0x0 HB=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/bin ACTIVETAKE=Main HOUDINI_DESKTOP_DIR=/Users/jeff/Desktop HD=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/demo HOUDINI_USER_PREF_DIR=/Users/jeff/Library/Preferences/houdini/16.0 PATH=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/binApplications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/houdini/sbin
Users/jeff/bin
usr/local/bin
usr/bin
bin
usr/sbin
sbin HOUDINI_VERSION=16.0.717 work=/work/ glue=/work//user/glue _=/usr/bin/printenv POSE=/Users/jeff/Library/Preferences/houdini/16.0/poselib PWD=/tmp proj=/work/proj JOB=/private/tmp JAVA_HOME=/Library/Java/Home jwi=/n/iowa2/tmp/jeff EDITOR=/usr/bin/vim jeff=~ LANG=en_CA.UTF-8 XPC_FLAGS=0x0 HOUDINI_BUILD_COMPILER=7.3.0 HFS=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources HOUDINI_MAJOR_RELEASE=16 XPC_SERVICE_NAME=0 prog=/work//user/prog HOME=/Users/jeff SHLVL=2 HHC=/Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/houdini/config LOGNAME=jeff CLASSPATH=.
Applications/Houdini/Houdini16.0.717/Frameworks/Houdini.framework/Versions/16.0.717/Resources/houdini/scripts/java/sesi.jar HIPFILE=/private/tmp/untitled.hip HIPNAME=untitled sesi=/work/sesi HOUDINI_PATH=~/houdini.jeff:& SECURITYSESSIONID=186aa
- SebastienMercier
- 1 posts
For new users the easiest way to see what these variables are set to is to fire up Houdini, open a Textport and type:/ -> echo $HOUDINI_TEMP_DIR /tmp/houdini_temp / -> echo $TEMP /tmp [/quote] Please what do you mean about Texport? In google i seach "how to acces to text port houdini" and I found https://www.sidefx.com/docs/houdini/ref/windows/textport.html it just say what Texxtport do but nothing how to find it... Please lets me know where we have to ptt this code into? / -> echo $HOUDINI_TEMP_DIR /tmp/houdini_temp / -> echo $TEMP /tmp
- Thomas4D
- 23 posts
- blackpixel
- 182 posts
- NicTanghe
- 244 posts
- jsmack
- 8221 posts
NicTanghe
How do you open a textport or i assume a console or a terminal.
Just open a text port is not really helpful advice.
Textport is different from console or terminal. The textport is part of Houdini.
I don't know how the advice to ‘open the textport’ to came up, but usually when Houdini crashes a window pops up saying where it saved the crash file.
- Fluadlwirt
- 1 posts
- jsmack
- 8221 posts
Fluadlwirt
So Houdini (Indie) crashed on me after moving a curve that affected a lot of Geos. Now I did the File->Crash Recovery->Open Crashfile steps but then got the Error message "Unexpected end of .hip file". Is there still a way to restore it? I still have a copy of the crash. file! Thanks in advance!
Nope! The crash file is garbage. Hope you saved not that long before it crashed.
- robertorodriguezmoracho
- 2 posts
- AslakKS
- 319 posts
- LukeLetellier
- 20 posts
AslakKS
Yes, you can set it with a package.{ "enable": true, "env": [ { "HOUDINI_TEMP_DIR": "C:path/to/new/temp/directory" } ] }
Replace the path with the path you want, then save it as e.g. myEnvironment.json in .../User/Documents/houdini20.0/packages/
This seems to change the temp directory, but not the autosave directory.
Edited by LukeLetellier - Feb. 6, 2025 15:17:56
- AslakKS
- 319 posts
- LukeLetellier
- 20 posts
