Thank you Side FX (Retopo tools rock)
   2679   2   0
I did try retopo before the new version and now. “Skin” tool under retopo is soo good and smart.
Speeds up retopo a lot.
I had to create this topic as im verry happy about this change.
Smal minor tweaks here and there but over all verry good change.
(when selecting points) or edge around an object for example finger to grow topology is there option to see how many verts have selected?
As what i seem to do is start finger topology (retopo) and then i want to use in some point “skin” tool.
Skin tool has option to adjust how many “Spans” (or verts) it created,
If i select edge arounbd the finger (it has specifc ammount of verts) atm i count the verst manually and then adjust “Spans” to same ammount before i use skin tool so they will mach up.
Would be nice to see how many verts i have selected so i dont have to manually count those.
But i dont mind. Anyhow THANK YOU for updating retopo tools!!
ISUther - you can turn on geometry information, to see how your selection. I made a little video to show you.. i think this is what you are looking for. Hit the D key for Display Options window.
Edited by fianna - Nov. 10, 2017 15:48:58
-fianna
Yes that will do thank you
