visualizer with a shortcut
3425 11 4- kahuna031
- 897 posts
Testing out the new network customization tools [www.sidefx.com] with attaching a shortcut to create a visualizer.
Drop nodegraphhooks.py file in $HOME/houdini16.5/python2.7libs/ select a sop node with an attribute other than P and press shift-x.
Edited by kahuna031 - Jan. 27, 2018 10:32:15
B.Henriksson, DICE
- CYTE
- 679 posts
- martinkindl83
- 260 posts
- kahuna031
- 897 posts
Nothing else needed than H16.5. Have you assigned shift-x to something else? Changed your python environment somehow? If you type this in a python terminal you can test if the file is accessed:
import nodegraphhooks reload(nodegraphhooks)
Edited by kahuna031 - Jan. 25, 2018 01:17:06
B.Henriksson, DICE
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
- kahuna031
- 897 posts
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
- kahuna031
- 897 posts
martinkindl83That's a Houdini bug. I got that and other display issues when creating visualizers through the gui too.
viewport doesnt update, but toggling visualization icon, does the trick
martinkindl83Yeah, would be nice with options for that. Problem is, then I need to write my custom gui and that might not update very well between Houdini versions. Another solution would be to bring up the settings window for the visualizer but I don't know if that's possible.
what about adding list box, if attribute should show up as vectors or numbers?
For now I'll change it so that it defaults to text if it's not a vector attribute.
B.Henriksson, DICE
- martinkindl83
- 260 posts
- kahuna031
- 897 posts
