STAMPING not using default value
   1053   1   1
Hi!
I've got a line (on the X axis) and I'm using the stamp function in a transform on its Y rotation:
stamp(“../copyMainBranches”, randTopRot, 0)
When I view the transform, I can see that the line has a rotation of about 30 degrees. It's like it's not getting my default “0” value.
When I change the stamping's default to another value and set it back to 0 again, the line is perfectly on the X axis again. But when I click and view other nodes in the graph, the line gets back to that odd 30 degrees orientation.
Is this a bug or am I doing something wrong?!
Thanks.
-Olivier
Have you specified randTopRot in the attributes list of the Copy node?
Also I think you might need to use “randTopRot” in the stamp expression.
Edited by Enivob - Feb. 17, 2018 16:51:39
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
