I have a problem I can't wrap my head around and would kindly appreciate any help on how to solve this:
The setup: I created a particle system, the points have an orientation attribute and tumble about. Instanced to each point are 48 objects.
The problem: I need to constrain an alembic object and camera to one of the points and match the points orientation (and thus the orientation of the instanced geometry). A point constraint works for the position. The constrained geometry also tumbles by using the orient attribute with look at mode set to ‘direction attribute from points’. However I can't get the constrained geometry to match the orientation of the instanced geometry. I tried getting an up vector from the points y axis, which didn't work either.
Am I at least moving in the right direction, or is the point constraint a dead end? Might maketransform be a solution?
Thanks in advance for any suggestions.
Constrain to point - cannot match constraint to point and instance orientation
1551 3 1- ckeddf
- 2 posts
- tamte
- 8551 posts
since Points constraint is just copying what Rivet Object does, it doesn't offer more commonly used attributes like orient, so you have to decompose your orient to Y-axis for upvector and Z-axis for direction
to do that you can use following pointwrangle on your points:
then in Points constraint put
zaxis in Direction Attribute
yaxis in Up Attribute
v@yaxis = qrotate(p@orient, {0,1,0}); v@zaxis = qrotate(p@orient, {0,0,1});
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jsmack
- 7762 posts
tamte
to do that you can use following pointwrangle on your points:v@yaxis = qrotate(p@orient, {0,1,0}); v@zaxis = qrotate(p@orient, {0,0,1});
I smell an RFE
- ckeddf
- 2 posts
tamte
That certainly does it, thank you very much!
