35894: Fatal error: Segmentation fault (sent by pid 0)
Saving application data to /tmp/houdini_temp/crash.untitled.muratkoptur_35894.hipnc
2018-03-18 14:04:02.416 houdinifx[35894:303] CFUserNotificationDisplayAlert: called from main application thread, will block waiting for a response.
Crash log saved to /tmp/houdini_temp/crash.untitled.muratkoptur_35894_log.txt
2018-03-18 14:04:09.706 houdinifx[35894:303] CFUserNotificationDisplayAlert: called from main application thread, will block waiting for a response.
Houdini not starting on Mac OS X 10.9.5
2453 3 0- mrtkp9993
- 1 posts
Terminal output when I started Houdini from terminal:
- malexander
- 5161 posts
- Cyzor
- 181 posts
- old_school
- 2540 posts
I had a similar DisplayAlert error using OSX 10.9.5 with H16.5 crashing on launch and I only use shells on the Mac so I can not verify if double clicking on the app works… I
Upgrading to High Sierra OSX 10.13.3 fixed the problem for me. Don't want to force an OS update on anyone but it is good to stay somewhat current on the Mac. That is if your other apps are supported with the upgrade as well.
