Hi!
I remember seeing some sort of feature to see what slows down your setup. Can't find where/what it is…
-Olivier
a way to troubleshoot what node is slower to process?
1624 2 0- olivierth
- 1010 posts
- olivierth
- 1010 posts
- old_school
- 2540 posts
You can also enable heat maps on nodes in the Houdini preferences.
Once you enable the Perfmon, all the nodes will have heat maps relative to the current network they are in so you can easily spot the slow operators.
Note: Compile blocks will show up as a single entry in the perfmon if you are using them. To debug the innards of a compile block, temporarily disable the compile block and debug insides.
As with all debugging exercises, do NOT leave any of these features on after finishing profiling your networks. Turn off perfmon, enable all compile blocks when done.
