how to extrude faces with group?
   3435   7   0
Not the only way…but I suspect you want to do it with nodes.
Your extrude distance and inset is run by parameters on the “Controls” node.
Edited by BabaJ - April 17, 2018 20:10:23
Offset Box Faces.hiplc (104.8 KB)
I found the one by BabaJ working but bit too overcomplicated for what it does.
Here's a simplified and faster version of solving this in the attachment. Features more procedural selections, less manual labor. AMA if needed
Edited by osong - April 17, 2018 23:27:47
Offset Box Faces v2.hiplc (68.4 KB)
https://twitter.com/oossoonngg [twitter.com]
The reason I did it that way is because the question was “by group”.
Essentially showing you how by grouping you can achieve unique results per group;
e.i. each group gets its' own polyextrude.
Yes it's complicated if your going to drive them all with the same values, but not if each are individualized.
Could really all be done in a single wrangle node.
thank you! i like glitchigami's way.
BabaJ
hey, no worries. I technically solved it by group as well, so we are both not wrong. In no way I wanted to undermine/minimize your effort.
Edited by osong - April 18, 2018 03:07:14
Yeah…should have shown why I seperated them out into groups but didn't really do anything with the work, like animating the extrudes and colorizing them.
Edited by BabaJ - April 18, 2018 04:58:46
Offset Box Faces.hiplc (288.0 KB)
If I bypass any misinterpretations of ‘words’…and go simply by the OP's picture…ie. how to go from box 1 to box 2, then it needs just 1 more node….the bevel…
