i'm newbie
tried to use the layered surface shop,
i used 3 layers: base layer and the other two upper layers using images with alpha chanel.
apply to a box sop with a shader node. and attach multiple layer & uv project nodes. i overlap the uv project try to make an overlaping texture.
evrything looks right except the compositing mode.
i was trying to make an overlapping texture (using alpha of each texture).
but the effect i got when rendered was the upper layer always ‘add’ to
lower layer texture(so the texture became brighter ). the ‘over’ mode in this SHOP parameter seems doesn't work. The open GL display in viewer show the right ‘over’, but only when rendered it doesn't look right.
how to set the compositing mode?
thx.
layered surface SHOP
6001 8 3- metaclay
- 122 posts
- edward
- 7766 posts
- metaclay
- 122 posts
- Simon
- 2199 posts
could you post a sample image, it should work. Is the alpha 100% white where you want it opaque and 0% where it should be transparent. And is the image 100% black where it should be transparent.
Also you will always get better texturing if you convert to houdini's rat format. Not sure if it is available in Apprentice or not though.
- metaclay
- 122 posts
thanx for the information.but wow that's quite weird …
the image has the proper alpha channel, the only problem that i don't use that 100%black on the RGB channel where it should be transparent.
coz, in my experience working in other 3d/compositing software , the RGB channel can be ‘whatever’ then i only need to add/adjust alpha channel to mask the image that's why i didn't think that i have to black out the part in rgb channel.
so that's the rule of houdini ? why is it like that??
thanx
thanx
- thomas.waldinger
- 10 posts
it's called premultipycation. Every compositing tool uses it, but some won't tell you.
mathematicaly what a over operation does is: RGB_Over = (RGB_BG * (1-Alpha_FG)) + RGB_FG.
If your foreground happens to be unpremultiplied (means you have nonzero RGB Values with the corresponing aplha values being zero) those RGB Values get added to the composited image.
I think there is no checkbox for premultiplying your texture in the VexLayeredSurfaceShader, so you got to be sure this happend before you put it there.
- craiglhoffman
- 252 posts
Most compositors will go funky if you use unpremultiplied images. This has been my experience from myCAPS days at Disney through COPs, Shake and Fusion. Some (like Fusion) have an option in the Loader to specify the image isn't pre-multiplied and does the pre-multiplication for you (it is a check box called “Multiply by Alpha” or something like that).
The only place where I have found this to not be the case is with Real Time graphics like OpenGL renders where things with transparency get premultiplied in the graphics hardware and you want them un-premultiplied. (This is the case with OpenGL Sprites in Houdini).
Weird.
-c-
Weird.
-c-
- Simon
- 2199 posts
After Effects gives you the option to say how the image was made, premultiplies or not. But I swear the result looks subtly different (even with the correct setting) to when you comp in Houdini, never worked that one out.
Same with photoshop, you can't remove an alpha to make the image transparent in the same way as if you render a tif (from Houdini) which has an “assiociated” alpha built in and opens in Houdini with the transparency already calculated. It's very annoying. They do supply a remove black matte option but you apply this after the transparency has been created and again it produces slightly “wrong” results.Crazy.
- malexander
- 5169 posts
It depends on how the programmer sets the blending mode in OpenGL. If your image is already premultiplied, or you don't want it to be mutliplied, the blend funciton must be set as
glBlendFunc(GL_ONE, GL_SRC_ALPHA_MINUS_ONE);
Otherwise, it should be to
glBlendFunc(GL_SRC_ALPHA, GL_SRC_ALPHA_MINUS_ONE);
But it's generally difficult to give the user control over that in any meaningful way. COPs/MPlay does it for displaying foreground/background comped images in the Display Options (Background, Foreground images are Premultiplied) because it comes up from time to time there.
Could be that the alpha is being multiplied twice somehow (which would result in the alpha being squared, identical to applying a gamma of 0.5 to the matte). Try adding a gamma COP with the gamma set to 2 and the scope set to the alpha matte to see if that fixes it.
