Is it possible to render all existing rops and also rops in obj levels one after the other?
So without manual links?
It is a file with over 100 different rops.
Can i achieve in hscript that a rop in an obj level takes the name of the obj level?
thanks.
Automating rops with python
2228 5 0- Christoph_H_
- 48 posts
- Enivob
- 2537 posts
Check out the bottom of this page.
http://www.tokeru.com/cgwiki/index.php?title=HoudiniPython [www.tokeru.com]
You can press the button on any ROP using Python.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Christoph_H_
- 48 posts
thanks. This is what I'm looking for.
My problem is that I have no experience with python. I'm just starting to get along with vex.
It would be very kind of you to give me a hint.
How should the script look like, with which I manage to create my own “mantra rop” with “output path with object names” from the selected objects?
Could I set the scene floor to be added to each one?
thanks.
thanks.
- skoora
- 17 posts
You can create mantra rop set to render only curently selected objects with script like this:
if you also want to set output path acording to object selection You have to simply construct it (using ‘hou.selectedObjects()’) and set ‘vm_picture’ parameter on mantra rop
mantraRop = rop = hou.node('/out').createNode('Mantra', node_name="mantra") selectedObjects = ' '.join(list(map(lambda x: x.name(), hou.selectedItems()))) mantraRop.setParms({'vobject': '', 'forceobject': selectedObjects})
Edited by skoora - May 14, 2018 18:40:38
- jordibares
- 655 posts
- Christoph_H_
- 48 posts
