pretty much what the title says : I've been creating a terrain using heightfield nodes in Houdini and my scene file keeps getting bigger. Before I begun the terrain it was under 1Mo, then as I kept advancing it grew to 290Mo.
Is there any way I can reduce that ? I'm pretty sure this is due to heightfield_paint strokes being cached directly in the scene file. Is there a way to cache strokes outside of my scene ?
File size getting out of hand when creating terrain ?
3692 4 1- opika
- 8 posts
- Olaf Finkbeiner
- 323 posts
- opika
- 8 posts
- opika
- 8 posts
That did it, my scene size is now back to 2Mo.
Thanks a lot Olaf !
A few things if anyone is interested in the solution : you have to create two nodes :
heightfield_output to save your file. Make sure your resolution parameter is equal to your height field size divided by grid spacing.
heightfield_file to read the file you just created. Set layer mode to “replace” and Size to your height field size.
When your file is saved make sure to click reset stroke on your paint node.
Thanks a lot Olaf !
Edited by opika - June 20, 2018 04:22:01
Val
- jlait
- 6205 posts
You can also cache out a height field with a “File Cache” SOP or File SOP as it can be saved as .bgeo.sc. This is a 3d file format, but it stores the heightfield as a 2d volume so will round-trip seamlessly.
The growing file size is probably due to heightfield paint. To avoid having to re-apply the strokes every time you load a file, it caches out the final painting you did as a layer. This will thus bloat the .hip file.
