Pyro OpenCL vs CPU - Why do the sims differ?
   1255   2   1
Can someone please give me an indepth explanation as to why the CPU vs GPU sims look different?
I have noticed when making a fire sim, GPU gives a bit more streaky and jagged sim (better licks) than a CPU sim which tends to be a bit more billowy with more ‘shrooms’ or rounder shapes in general.
Sadly GPU crashes on any large scale sims yet I really like the look.
How can I get CPU sims to look as streaky and jagged as GPU?
Any tricks to stop a GPU sim from crashing?
Cheers!
The sim should be the same whether running OpenCL on the CPU or GPU. Toggling openCL is more likely to be the culprit.
Cheers, sorry I meant Open CL using the GPU vs simply not using Open CL.
I didnt know (Atom on odforce mentioned)you can change it to Open CL CPU in the .env file.
So thats great, do some R&D with OpenCL GPU, then final sims with CPU Open CL!
