procedurally take group points to use them in add SOP
   1053   3   0
Hi!
I grouped 3 points from scanned data.
group : 1182636 1255321 2282324
…I would now like to have an add SOP set to Polygons/by pattern to use those point numbers. At the moment, I have to manually copy/paste the point numbers…
-Olivier
You could use the by group of the add SOP and sort your point numbering beforehand; and as you have it shown now, all the points are in ascending order from least to greatest, so you don't need to sort and it will do it in the same order(with group)
Ah!
I'll bypass this problem by creating and snapping 3 points on the geo rather than grouping points from the scanned data. That way, my 3 created points will always be 0, 1, 2.
-Olivier
Ah! (I posted before seeing your post)
Good to know. I'll still try creating and snapping points on the geo. Grouping points on 4 millions poly meshes is annoying!! Snapping should be easier.
-Olivier
