Particle banking rotation
3951 4 0-
- JoshFoster
- 12 posts
Hi all,
I'm having a difficult time adding smooth banking rotation to particles. From the older threads that I looked at like this one [www.sidefx.com], it seems the popular recommendation is smoothing in CHOP's, however I'm trying to avoid this route because my understanding is CHOP's isn't multi-threaded and doesn't scale well.
Attached is the test file that I've been working on. I have the bank angle set to the magnitude of the XZ acceleration. Is there an operator or VEX expression that will smooth an attribute over time? Any help or hints would be greatly appreciated.
Edited by JoshFoster - Oct. 3, 2018 12:37:37
- Enivob
- 2658 posts
Check out the lerp function.
http://www.sidefx.com/docs/houdini/vex/functions/lerp.html [www.sidefx.com]
Or maybe the AttributeBlur node.
The problem may be in this line.
If you examine the result of angle you will discover that is can exceed the range values you have specified. When that happens, you are losing resolution in your values and the fit will act a bit like a clamp. It might be better to clamp the xy_accel_mag so the resulting angle falls within the fit range.
Is bank_angle output supposed to be in radians?
f@bank_angle = fit(angle, -PI/2, PI/2, -PI/5, PI/5);
Edited by Enivob - Oct. 4, 2018 10:27:54
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Enivob
- 2658 posts
The jitter does seem to be related to the distance from curve. When I copy a few boxes along the path I can see that the boxes closest to the curve points exhibit less jitter on banking than the ones farther away from the curve/path.
- brianBurke
- 192 posts
- JoshFoster
- 12 posts
