Resolved : [Alembic] How to know if an alembic was created with Maya or Houdini (in Python in Houdini)
   1542   4   2
Hello!
I am trying to find a way to do such a code in Houdini:
import alembic.Abc as abc
test = abc.IArchive("test.abc")
archive_infos = abc.GetArchiveInfo(test)
if "appName" in archive_infos:
    app_name = archive_infos["appName"]
    print("\"{0}\" was created by \"{1}\"".format(filename, app_name))
And then, depending if the alembic file came from Houdini or Maya, I will do some treatment or some other.
I tried with :
alembicGetSceneHierarchy but I haven't found a good way!
Edited by Francois Devic - Oct. 15, 2018 12:19:52
might find something here:
http://www.sidefx.com/docs/houdini/hom/abc_extensions.html [www.sidefx.com]
Training Lead
www.sidefx.com
goldfarb
Unfortunatelly, I haven't found what I am looking for…
The “abcecho” command line tool will report this information. There is currently no convenient way to access the information through the Alembic HOM extensions.
derrick
Thanks a lot!
It makes the trick
using a subprocess.Popen, I can read anything inside the file so it works for me!
