I'm new to Houdini, and I'm following a tutorial, but on the texture vop node they have ‘S’ and ‘T’ inputs. I can't find them? I'm using Houdini Apprentice 17.0.352. Basically what I have done (I apologise if I don't explain this very well as I don't really understand it myself) I've fed points in to a uv texture node and then that into an attribute VOP. Then inside the VOPI've imported the uv attribute, and fed that into a vector to float, but then the ‘fval1’ and ‘fval2’ on the tutorial are fed into the S and T inputs in the texture node?
Thanks a lot
Josh
S and T Coordinates Texture Vop Node Houdini Apprentice 17.0.352
1797 1 1- Josh Wibberley
- 13 posts
- tamte
- 8595 posts
