1. in shop level ( i'm previewing shader on viewer), i can preview both surface and displacement shader simultaneously.
but if i created the shop network inside sop level, i cannot do something like this. how to fix this?
2. in a node parameter (example : group node) i try to ‘save as permanent default’. but it always give me an error :
couldn't sae presets “new preset” to $HOME/houdini8.0/presets/Sop/group.idx
check file permissions,
i'm sure i've checked this path over and over….and it's there correctly with the right read/write permission. still i cannot write to this file. why?
anyone can help?
displacement in shop
6626 7 1- metaclay
- 122 posts
- pbowmar
- 7025 posts
- moreguns
- 22 posts
- JColdrick
- 4140 posts
- moreguns
- 22 posts
I'm new to any other “deformation/displacement” possibilities (just getting started) but if there are other alternatives please let me know what they are and how they would work (via Houdini or anything else).
My goal is to quickly change a model's form into the shape of something else (similar not too drastic), like a “pugg” nose into a straight nose or vice versa. Or a small ear to a slightly bigger ear (to reiterate) and afterwards have the actual geometry change to fit the new displaced data.
(Sorry for the redundancy).
So again, yes, it sounds like this would work according to your answer. But how is this achieved within Houdini? Can a container be used that does this for me (compare the model to be changed (displaced) to the “displacer” model (style used))?
thanks again
thanks again
- JColdrick
- 4140 posts
There's never any absolutes, but I probably wouldn't use disp maps to change a long nose to a pug nose - I'd build the two models from the same basic shapes and blend between them using the blend SOP. It's just that a nose is fairly complicated and twists around in space what with nostrils and such - it's not just an extruded grid.
That aside, you could write a shader in VOPs that blends between two image map inputs and use that as a displacement, should you want to do that.
J.C.
J.C.
John Coldrick
- moreguns
- 22 posts
- JColdrick
- 4140 posts
