Curve Extraction
4662
7
2
- sascha
- 158 posts
How can I extract a curve from an edge loop?
- wolfwood
- 4262 posts
Please provide more details. Polygons? NURBS?
Carve SOP might help.
- sascha
- 158 posts
Wolfwood
I want to extract or convert a selection of (poly) edges into a nurbs curve.
- jesta
- 311 posts
the problem is having consistent point numbers to do it.
here's a .hip file with a hack to do what you want.
you just need to make sure the poly loop is on the edge of the points you want to select.
I'm sure there's a cleverer way. I'm just not cleverer.
Jerry
edge_loop.hip (100.9 KB)
- Simon
- 2199 posts
check out the divide sop with the remove shared edges option on, that might help.
Use convert or fit sops to turn the result into a nurbs curve.
- sascha
- 158 posts
How can I close the curve after a convert SOP?
- Simon
- 2199 posts
Use the ends sop. Might be better to do it before though.
Also, try adding a basis sop after the convert and making the knots uniform
- sascha
- 158 posts
Simon
Thanks, that works fine.
