Pixel Parser
6463 5 1- sascha
- 158 posts
- JColdrick
- 4140 posts
- jesta
- 311 posts
sascha
I need VEX shader which parses a bitmap texture pixel by pixel to asign a different pixel color value to each particle id. Or can I get the same effect with a bitmap input through another method?
It really depends what you want to do. As always a little more information is helpful.
There's usually more thatn a couple of different ways to do things in Houdini.
Jerry
- sascha
- 158 posts
- JColdrick
- 4140 posts
I recommend you take the basic topics and cover them, rather than specific questions in contexts that aren't clear at first. There's so many ways to do this, it might be more confusing to be asking lots and lots of short questions that might be more apparent if you walk through a broader range of tasks.
Just as an example - middle mouse over the sphere copy example(the first color POP example referenced), and you'll see there's a point attribute here - Cd. In the Copy SOP you'll notice they specifically told Houdini to copy this attribute over. However, it's just an attribute, not a final shaded colour. You need a shader that accepts that attribute, then passes that either to a shading model, or directly out if you want. You can quickly make one by creating a VOP shader with a Shader Layer VOP, set it to RGB color, then feed that to Cf. Assign it to the copied spheres, ensure the render flag is set for the Copy SOP(it isn't by default I believe), and hit render.
J.C.
J.C.
John Coldrick
- sascha
- 158 posts
