animation editor: change tangent type to one keyframe only
   6516   10   3
Hello everyone.
very basic question, I hope someone can help me. I want to change tangent type (for example bezier to linear) to some keyframes in the animation editor, but using the dropdown menu Houdini converts an entire segment, and not only the selected keyframes. I'm showing what I'm trying to do in the attached video using Maya.
Thank you
Ray
Edited by madrenderman - March 25, 2019 08:28:48
curves.mp4 (1.4 MB)
The function type is a property of the segment, not the keyframe.
Edit, after watching your video, you are looking for a way to automatically match the tangents to the slope. I'm not sure if there is a way to do that.
Edited by jsmack - March 25, 2019 14:43:57
Does selecting the slope and hitting 9 help?
9 is the same as “flat tangents” in Maya, if there was also “spline”, “linear” and “stepped” I would have solved the problem
this probably isn't exactly what you're asking for, but you can break tangent continuity at the first keyframe, and then use the ease-out segment type.
seg_ease_out.mp4 (363.1 KB)
john mariella
Senior Technical Director
www.sidefx.com
madrenderman
9 in Houdini's animation editor is to do “smooth” slopes, which is to adjust the slope so that it's in the direction between the two adjacent keys, unless both keys are above/below it, in which case it goes “flat” to avoid overshoot.
Edited by edward - March 26, 2019 00:08:13
Thank you guys, there is some workaround but it's not the same function as Maya and I think it's really important for keyframe animation work, I sent a feature request to sidefx support, fingers crossed
Please check in the next builds 17.0.533 or 17.5.208.
I added Set Selected Slopes to Linear to the Animation Editor.
It isn't exposed yet as a button, but you can get to it from the Edit menu or the right click menu.
It is also bound to the ‘8’ key.
So, ‘8’ makes a slope linear, ‘9’ smooth the selected slopes and ‘0’ zeros the slope.
If you have both ends of a slope selected, the out slope will be used.
If you want to break the slopes, you can select a slope handle and hit ‘T’ to tie/untie.
Wow, what a support ! Thank you I'm looking forward to test the new build
Did it work? I received a forum notification by mail, but it seems the message was deleted.
Edited by Guillaume - March 29, 2019 15:35:25
Guillaume
“Makes a slope linear” seemed has some bugs in 18.0.509.
Select first key frame may cause slope accel to NAN.
Edited by jerry7 - July 4, 2020 10:35:10
