How to edit $PT attribute manually
   6397   7   2
Hi, guys!
I'm trying to create a curve based on points selected from a deforming mesh. To get the right curve it is very important for me to sort points in right order. Sort POP doesn't help me.
Does anybody know, how to sort points manually?
Try the Add SOP. On the Points Tab click “Delete Geometry But Keep Points” and on the Polygons Tab type in the old point numbers in the order that you want.
Thank you very much! That's what i needed
Or try just snapping a curve to the mesh with the snap conslidate option turned on. You will find your curve permanently referenced to the source mesh as it deforms, very handy….
Simon
Great tip Si
Simon
Yeah, cool!
OR….wire mesh to empty Curve SOP…and reference the coordinates of points in the input geometry….like:
p31 p30 p28 p26 p7 p8
AndrewVK
