Weight Map for POPs
   3173   1   1
Dears,
I was wondering if it could be possible to create a similar effect in Houdini.
https://www.youtube.com/watch?v=wePK9PQanzs&t=126s [www.youtube.com]
Of course, if it is a field to study I just want to know it, I'm a noob in Houdini
Edited by Ros - June 15, 2019 12:14:11
Kind regards and good day,
Rosario Rosato
I was curious, so had a look at your video link.
Although I don't know how to specifically do it. I do know it is possible.
If you actually want to go ahead and re-create the same thing the first step is going to be learning how rigid body solvers work in a dop net.
One example from the SideFX tutorials section that could get you started:
https://www.sidefx.com/tutorials/applied-rigid-body-destruction/ [www.sidefx.com]
There are others, just enter search words like Rigid Body or Collision in the Learn > Tutorials section.
There is also a 3 part webinar under Learn > Talks and Webinars under the drop down ILLUME Webinar - Jeff Wagnar; Collisions.
I don't think you will find a specific tutorial to do exactly the same thing but if your just starting there will be important concepts that help you understand how to work in a dop net, and eventually get what you want.
