How to add values to an array?
1219 2 0- Shadowjonny
- 97 posts
- Andr
- 900 posts
- BabaJ
- 2041 posts
No, you can't generate arrays of arrays in vex.
However, you can make a quasi type setup to accomplish something similar; It's just not efficient as it can chew up a lot of memory and processing if it gets big.
Would be good if we had that capacity in vex(arrays of arrays) where under the hood it's referencing the members by pointers, rather than having to generate attributes like I have with the example hip.
For your other questions, here's a doc reference so you can choose how you want to work with your example:
http://www.sidefx.com/docs/houdini/vex/functions/index.html [www.sidefx.com]
