Lava Flickering
   1214   2   1
Just need some help with my render.. How do i remove the flickering in here?
I already adjusted the Raytracing Bias from .001 to .01 and Pixel Samples to 8. Also, it needs to have displacement so i enabled the Noise Displacement in the lava shader.
-TIA
Francis
Edited by fandalis - July 26, 2019 08:12:29
This looks like unstable meshing and not directly the renderers fault.
https://www.sidefx.com/docs/houdini/nodes/sop/particlefluidsurface.html [www.sidefx.com]
This might also be related to your displacement if your rest attributes are not correctly setup.
https://www.toadstorm.com/blog/?p=312 [www.toadstorm.com]
Thanks for your reply and the links! Will definitely check on this. I have only the default settings on the video above.
