Wall Won't Stay Glued to GroundPlane
   1062   2   0
I have a simple RBD setup- the Wall and the Ground Plane are glued together, yet the Wall jumps off the Ground plane when impacted by the sphere. How can I get the Wall to stay put on the ground plane? Scene File attached. Thank you!
BoxSmash.hiplc (532.5 KB)
Brad Schreiber
Here is your file back with some changes. I did a lot of things but the main one was I used a real grid as the ground plane. The shelf attempts to bring the “virtual floor” back into SOPs to build the constraints, but this won't work.
BoxSmash1.hipnc (469.5 KB)
Sean Lewkiw
Machine FX - Cinesite MTL
Thank you!
Brad Schreiber
