I'm just starting to learn houdini and loving the potential it seems to have for doing just about everything and noticed with the little work i've done in attribute vop nodes and building materials, that it appears to be a lot like substance designer.
So I was curious, I love designer, but would love even more to be able to do just about all the same stuff directly in houdini. Is that possible and are there any good lessons around to help learn that? The material lessons in tutorial list look like they mostly cover rendering and settings for that, not a lot on really building out complex surfaces/materials.
How close can you get with VOPs/COPs to Substance Designer?
2025 2 1- proximo
- 25 posts
- mestela
- 1742 posts
I've not used substance enough to have an informed opinion, but from what I've seen its not just the tech that makes substance interesting (its ultimately a 2d compositor and paint package), but its the library of texture nodes and workflow that make it good at what it does.
The feature set of cops have interesting pros and cons. It's built into houdini, supports vex and vops, can has the ability to move data between 3d and 2d, all great. It's also little old, slow, unstable compared to other compositors.
There's not a lot of substance specific tutorials around as it would take some effort to get it to parity, but there's some interesting developments. Maybe you can be the one to tie it all together!
Quantico is creating a lot of cops nodes that are emulations of interesting substance nodes. https://www.sidefx.com/forum/topic/69233/ [www.sidefx.com]
The gamedev/sidefx labs new maps bakers use cops under the hood to generate base maps and transfer high->low, like substance does, this presentation explains how its done: https://www.youtube.com/watch?v=B8HqBuH9xew [www.youtube.com]
Fabrico Chamon is very busy, he made a full substance style cops thing about a year ago, I'm sure it'll give you some ideas: https://vimeo.com/288436861 [vimeo.com]
- proximo
- 25 posts
