Hello
I'm trying to find a way to expose the length of a curve in hda.
I'm using Measure node to measure Perimeter from Primitives, and attribpromot to send it to detail.
But I'm stuck when I want to expose the perimeter float value, just ‘for information for the final hda user’.
Can you explain to me how to do it, please?
Expose Curve length on hda
1856 8 0- innocent
- 35 posts
- BabaJ
- 2042 posts
- innocent
- 35 posts
Yes, I agree with you but I don't know how to do it.
My perimeter value = 46.18
on an attwrangle, when I test to store @f = detail(1, ‘perimeter’); that gives me 0.
I miss something…
@f = @perimeter;
how to store or target this on a spare parameter ?
I find :
expression on spare param : detail(“../attribpromote2”,“perimeter”, 0)
I miss something…
@f = @perimeter;
I find :
Edited by innocent - June 16, 2020 13:13:20
- innocent
- 35 posts
- BabaJ
- 2042 posts
You could do it the opposite way for that.
Instead of dragging and dropping the parameter that has your perimiter value.
Create a spare parameter through type properties of the asset.
Then Save Node Type and Match Current Definition.
Now drag and drop the parameter inside the asset that has the perimeter value into the new spare parameter of the asset to create a relative reference (now don't do the drag and drop type of operation one normaly does for an asset creation). Your dragging and dropping on the asset node itself not the asset interface.
Once you've done that click the assets cog icon and save preset.
- tamte
- 8597 posts
to have it being a part of HDA rather than a preset you can put your expression as a default value in Type Properties for your parameter
then also you can disable it bu having hidden parameter set to 1 and your length parameter have disable when conditional
or it's also common to create LAbel parameter and put the `detail()` expression in there which will pull the value from the geo
on the flip side having UI values depend on cooking geo can drastically slow down the interactivity and may be causing unnecessary recooks even if the geo is supposed to be still cached, not sure if this is still happening, but was an issue in the past
Edited by tamte - June 16, 2020 16:38:57
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- BabaJ
- 2042 posts
- innocent
- 35 posts
- innocent
- 35 posts
