Rendering issue with houdini apprentice
   2082   4   0
I am new with houdini but I got an issue with the rendering part.
Currently, I got the apprentice version of Houdini. I put my render object to the left of the camera , when I render , the object is always in the center of the scene.
So I've tried to change the camera orientation , the scale of the object, I've tried with the transform node but the result is always the same.
In case where I buy the indie version of Houdini , my problem will be resolve?
Can I you help me ? because I really don't know what to do
Thanks you in advance
An issue like that is not going to be resolved by an upgrade( in terms of features )…post your hip so people can see what the issue might be.
Have you tried locking the camera to the view and then rotating the view? Is your render set to the camera you are manipulating?
Are you zoomed in to the RenderView? Have you tried zooming out?
>>Kays
I've tried everything that you have said,and I found the solution. I have passed all this week to figure out and I found.
In fact the problem was in the render node where the mantra render was forced to render the previous version of my object.
Thanks you a lot for your help
Ange
