I am trying to get a direct refract through LPEs.
I did get the whole refraction result with:
C<TG>.*
Can anyone help me to just the direct refraction?
Thanks.
Light Expression Help with refractions
7019 6 0-
- mzigaib
- 1067 posts
- mzigaib
- 1067 posts
- dlee
- 489 posts
Hi. The distinction between direct and indirect is the number of scattering events. If there's only one between the camera and the light, then it's direct. If there's more, then it's indirect.
So, direct refraction could be:
C<TG>L
Indirect refraction:
C<TG>.+L
You could substitute
C<TG>L
C<TG>.+L
[LO]for Lif you want to count emissive objects as lights.
- tamte
- 9737 posts
- jsmack
- 8381 posts
dlee
C<TG>L
C<TG>.+L
You could substitute[LO]forLif you want to count emissive objects as lights.
Closed form solids are unlikely to have any direct refract events reach the camera. I've found a good substitute for ‘direct’ scatter in the pathtracer's definition is for direct from an artist's perspective. Where the path is defined as a ray that interacts with the refractive surfaces only before reaching a light source. This way light coming through a window or glints in a rain drop would be described by this event. The question is, do you also put internal reflections in this bucket? As gemstone ‘fire’ is more of an internal reflection that's transmitted back through, i.e. TRT, or TRRT etc.
- mzigaib
- 1067 posts
Dudes! Thank you very much for the feedback.
That seems to work but it seems that mantra works differently in the direct refraction I don't get the blueish color that I have in my interior volume and speculars are a little different even using the same shader and lighting but I think that is normal.
Anyway thanks again for the help.
- tamte
- 9737 posts
jsmackso you mean something like
lpe:C<TG>+L
lpe:C<TG>[^<TG>].*L
EDIT: embedded lpes as code as they were not showing correctly
Edited by tamte - Sept. 25, 2020 11:37:48
