Here's a simple scenario I've often had to do in order to render lines and points at a constant raster size: I need to modify pscale before providing geometry to the renderer by referencing a camera position, and then alter pscale by distance to camera. Throw in other attributes like brightness, etc..
Is it faster to make modifications like this in a SOP modify or natively with a wrangle in a LOP context?
USD primvar wrangle vs. SOP wrangle performance
3771 2 0-
- jparker
- 333 posts
- tamte
- 9746 posts
While can't answer that, just want to mention that you can also potentially use Hengine Dynamic Payload which is new in H18.5 to let the change be computed when the payload is being loaded rather than during LOP execution,
(Essentially it's the sop import way, but delayed, not sure what are the hengine license implications though)
- jsmack
- 8381 posts
tamte
It would have to be a self contained hda, or have the geometry it modifies passed as a file path parameter, as there's not a way to pass geometry on the stage to an hda payload.
