how to stick a picture onto an object? I tried the rest positon sop, but it doesn't work for me.
I want to make a ground broken effect with camera projection method, and how to stick the image onto the ground? So when it cracks, the textures could move with the objects.
I found there was a posted topic about the renderman refrence object using “_pref”, but I cant find it, anyone can show me the link?
how to stick picture onto an object ?
5553 4 1- ykcosmo
- 288 posts
- old_school
- 2540 posts
Many ways to do this. Here's a couple.
FSee how far up the chain you can create the uv's. Preferrably on the geoemtry just before you deform it.
You can lock down the effect in a SOP, apply uv's to the static locked geometry then using the second input of the Point SOP use $MAPU2 $MAPV2 and $MAPW2 for the Texture parms to transfer the uv's over to the deforming geometry.
Rest SOP generally works for procedural shaders, not texture maps.
- sjowol
- 11 posts
- sjowol
- 11 posts
- ykcosmo
- 288 posts
