Instancing Leaves orientation / transformation issue
   1339   1   0
I am new to Houdini and having a really difficult time trying to instance my leaves from a tree model I created inside Speedtree. I am importing the speedtree model as an alembic.
1. I have pulled the transformation matrix and promoted them to points, however when I copy grid to points the transformation is repeating the same number over every point leaving me with no transformation.
2. I have pulled the orient attribute to points used a for each loop to extract points and packed inside the loop, this way gets me closer, some transformation but it is not the same as the original orientation.
Screen Shot 2021-05-30 at 8.08.07 PM.png (1.8 MB)
Screen Shot 2021-05-30 at 8.07.55 PM.png (1.5 MB)
Screen Shot 2021-05-30 at 6.52.50 PM.png (379.1 KB)
I think you should try first to convert your "transform" matrix into quaternion and get an @orient attribute on points
Try to do this in VOP or VEX
take a look at this maybe :
https://www.sidefx.com/docs/houdini/nodes/vop/matxtoquat.html [www.sidefx.com]
https://www.sidefx.com/docs/houdini/vex/functions/quaternion [www.sidefx.com]
you can find as well interesting stuff here : https://www.tokeru.com/cgwiki/index.php?title=JoyOfVex17#Orient_via_matrix [www.tokeru.com]
