How to make houdini crash to save a crash file?
   7458   5   0
Hi!
maybe it's a funny problem, some times houdini may hang and i have not saved the file.is it possible to make a memory error or something to ask houdini save the file in tmp folder? both widows and linux.
https://vimeo.com/user3971456/videos [vimeo.com]
I rarely see Houdini "hang". When it is unresponsive, it generally is calculating something. Check the lower left corner of the application for status messages. Try pressing the ESC-KEY to stop the calculation. Also, there is a "backup" folder were you can recover the last version of your project if you force quite Houdini.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Apologies on reviving an old thread - but it hangs quite often for me. The entire interface will turn grey, it will say "Not Responsive" in the top menu-bar, and nothing appears in the bottom left corner's text readout because the entire UI is greyed. Usually it is indeed processing something still, but pressing escape doesn't do anything, and I just have to wait for it to finish whatever it is trying to do.
On linux you can send a SIGSEGV or SIGFPE signal to kill it and still try to generate a crash file. There may be other signals that also generate crash files, but SIGKILL does not.
On Windows, you're out of luck as it doesn't have signals.
Yes, on Linux:
kill -SEGV PID
works, or
killall -SEGV houdini-bin
(you have to check with ps -ef to see what "houdini" is on your system.... it might be houdini-bin or houdini-fx or something like that).
Sean Lewkiw
Machine FX - Cinesite MTL
mrCatfish
Yes, on Linux:
kill -SEGV PID
works, or
Also works on MacOS!
