voronoi Fracture pieces
1128 1 1- luidox
- 36 posts
Hey everyone, is there a way to delete random pieces of a voronoi fracture set up? is it also possible to have them only show up on say edges of ojbects? Im trying to create a Boolean to cut into some edges of rock
looking at the last image, i need the inverse of this but to keep the whole chunk intact
Edited by luidox - July 7, 2021 13:31:40
- Berk_Erdag
- 86 posts
I am not sure if I understand you correctly and if you are looking for the screenshot below, I basically packed the fractured geo with an assemble SOP. Then put some geometries with mountain SOPs around the corners to select a few points and delete them. Or chose some by hand and just blasted them.
Check out the hip file.
Edited by Berk_Erdag - July 8, 2021 06:31:15
