I have a HDA Processor node and before it I have a PartitionByIndex. In partition I have 2 outputs with 2 tags, how show I enter them in the next HDA Processor so that they would work?
If I enter the exact path of the output - it works. (ex. C:/somewhere/something.bgeo.sc )
If I delete ALL tags - it works.
If I write 2 tags as in the node above - it doesn't work. ( ex. picture )
If I use wildcard* - it doesn't work. (ex. file/geo* )
PDG - TAGs
2396 1 0-
- archizt
- 3 posts
- tpetrick
- 626 posts
The tag field only allows you to specify a single tag value. Tags are hierarchical -- specifying a tag string of file/geo will match both file/geo and file/geo/allareas, so in your case that's all you need to use. There are more details in the documentation: https://www.sidefx.com/docs/houdini/tops/filetags.html [www.sidefx.com]
