Detail Attribute Returning 0
   3652   9   0
I have a detail attribute that is a number.... I need this to set my max frame range for a ROP.
`details("../attributepromote1//", "myAttrib")`
Returns a "0" instead of the number "2" and gives the error below.
Error: Unable to evaluate expression (Syntax error (/obj/Main_Object/rop_geometry1/f2)).
Vincent Griffith
Edited by VGriffith - Nov. 17, 2021 21:55:57
try detail() instead of details(). details is for getting string attributes while detail numeric attributes.
The syntax error is from the backticks around the expression. These are only for evaluating expressions as literals in string parameters. Numeric parameters always evaluate expressions because the expression is always a keyframe.
This is not working, the detail is still showing up as zero with all these suggestions...
VGriffith
Can you post a hip file or screen grab of the expression?
Edited by antc - Nov. 18, 2021 18:42:19
FOUND OUT WHAT WAS WRONG. I needed to promote the detail attribute with the value of "2" to a primitive value, use
s@string_attribute = itoa(i@int_attribute);
to convert it from an integer to a string... then I promoted it back to a detail and used
and then it worked.
Edited by VGriffith - Nov. 18, 2021 19:31:36
Working Correctly.hiplc (140.2 KB)
Glad you found a solution but none of the promotion or casting is needed. Just a switch from details() to detail() does the trick (hip file attached).
Edited by antc - Nov. 18, 2021 20:28:22
WorkingCorrectly.hipnc (164.2 KB)
I see that I cannot use the detail function in a field that expects an integer otherwise it sets a key.
At least this is true for frame range fields.
So I added an null (exactly like the example file above) and that null had a string attribute that I put the detail function.
then I copied a reference to this field and pasted it into the frame range field and it now works.
Edited by geordiemartinez - July 13, 2022 20:15:59
geordiemartinez
What's wrong with setting a key? no ` required. I use keyframes on string parameters too.
I can't get it to work in a time range attribute on an Alembic ROP the same way it would in a string attribute. I don't want to set a key because I will use different length alembics and always want the end value to be relative to the alembic length.
