What's the main difference between Cache SOP [www.sidefx.com] and Stash SOP [www.sidefx.com]?
Their use cases seem very similar to me. Both cache input geometry (except Cache provides a secondary input to invalidate cache?) When to use which then?
Cache SOP vs Stash SOP?
1479 3 0- raincole
- 448 posts
- Andr
- 900 posts
- jsmack
- 7839 posts
raincole
All (sop) nodes cache geometry. The difference with the cache node is it caches a copy of the geometry for each frame of animation. It's useful for fast playback of geometry. It also has uses for when a node needs to cook multiple time steps at once such as timeblend. The cache is transient, it is lost when changes are made upstream or when closing the scene.
The stash node on the other hand saves a copy of the input geometry as a parameter value--making the geometry persistent. The stash node does not pass through its input.
Edited by jsmack - Nov. 27, 2021 21:48:52
- raincole
- 448 posts
jsmack
Thank you very much! Finally got it.
