Hi, wondering if there is a better way to flip a node between hda versions than going through that massive dropdown on the Change Node Type Dialog (from a node's Actions > Change Type ... context menu). With the wonderful new Labs Digital Asset context menu that allows for major/minor versions to be created and managed so much more easily... I thought there might also be an easy way (perhaps from that menu even) to flip the node to a particular version.
Seems like the right place for a nice qt dialog akin to preferences that lets you easily browse and select the versions it manages for the selected node type in major/minor version streams.
Simpler Node > Actions > Change Type
1094 4 0- sdugaro
- 380 posts
- sdugaro
- 380 posts
- jsmack
- 7850 posts
- sdugaro
- 380 posts
- wlvl_r
- 4 posts
Is there a way to access that "Asset Name and Path" drop down menu and change it with Python?
My goal is to analyze a scene a switch all "outdated" hdas to the latest definition available.
Note that my hdas are saved as separated files on disk:
HDA Name
mypipe::myhda::1.0
mypipe::myhda::1.5
mypipe::myhda::2.0
On Disk:
pathtofolder/sop_mypipe.myhda.1.0
pathtofolder/sop_mypipe.myhda.1.5
pathtofolder/sop_mypipe.myhda.2.0
Thanks in advance
Davide
HDA Name
mypipe::myhda::1.0
mypipe::myhda::1.5
mypipe::myhda::2.0
On Disk:
Thanks in advance
Davide
