Local maxima?
1047 2 1- vinyvince
- 255 posts
For several cases, I have this need to find the local maxima for a parameter or for a heightfield volume.
For now, the only thing I could think about is to split into cluster
Is there a better algorithm for this?
Have you faced this question before?
If so I'm interested to hear your words
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- tamte
- 8551 posts
- for parameters do you mean local maxima of animation curve?
you can use CHOPs for that for example Channel Wrangle:
- for heightfields you can do it in a similar way in Volume Wrangle, imply compare height of a current voxel to its neighbors and if all of them are smaller place a point or something (Volume Wrangle on isolated height volume):
float prev = chinput(C, I - 1); float next = chinput(C, I + 1); V = (prev <= V) && (next <= V);
float h = @height; vector i = set(@ix, @iy, @iz); vector is[] = array(i + {1,0,0}, i - {1,0,0}, i + {0,1,0}, i - {0,1,0}); // orthogonal neighbors vector is2[] = array(i + {1,1,0}, i + {1,-1,0}, i + {-1,1,0}, i + {-1,-1,0}); // diagonal neighbors append(is, is2); int ismax = 1; foreach(vector ni; is) { float nh = volumeindex(0, "height", ni); if (nh > h){ ismax = 0; break; } } if (ismax) { int pt = addpoint(0, v@P); vector P = v@P + set(0, h, 0); setpointattrib(0, "P", pt, P); } removeprim(0, @primnum, 1);
Edited by tamte - May 7, 2022 11:47:29
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- vinyvince
- 255 posts
Wow, i didn't know much people who you will have be able to provide such a great and smart solution here, you are a true houdini rock star Tomas!
Didn't noticed your example until now but it was easy to get it , Thanks you so much for sharing your knowledge! @tamte
Edited by vinyvince - May 7, 2022 17:49:20
