UV transform Question
1060 3 0- eveying
- 19 posts
- jsmack
- 7801 posts
- eveying
- 19 posts
- tamte
- 8583 posts
main issue is that your points lay directly on uv borders
so right most points of one tile have the same u coordinate as leftmost of neighbour tile
which makes it difficult to offset correctly using point uv coordinates directly
there is man options, but the most straightforward in your case may be getting average uv per prim which will be within the uv tile for each slice and therefore you can clearly compute the offset to move them to 0-1 tile
Edited by tamte - June 1, 2022 03:59:30
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
