Hi!
I've got a simple subnetwork with some channels exposed. Inside, there's a Detail Wrangle with a i@pieceCount. I want to disable a channel of my subnetwork when @pieceCount is below a value but using:
{ pieceCount > 2 }
...clearly doesn't work. Any tips on how to do this?
-Olivier
Disable when: using Detail attrib inside subnetwork?
731 1 0- olivierth
- 1013 posts
- jsmack
- 7849 posts
by disablewhen do you mean switchif? Disable when is for parameters. parameters can only be controlled by other parameters, not attributes. You could add a dummy parameter to hold the value of the detail attribute, but that would make the parameters dependent on the cooked input which is a big no-no.
