editableStage() does not work in Expression context, its return value is None.
Or maybe there are other ways to read the attributes of LOPs USD primitive in Expression?
2802 14 1- ysysimon
- 75 posts
- ysysimon
- 75 posts
- jsmack
- 7771 posts
- ysysimon
- 75 posts
- tamte
- 8555 posts
there are 2 issues with your expression
1. you are trying to get stage of the current node, which would cause a recursion since the expression needs to cook to get that stage and the expression needs the stage to cook
(it's the same issue as if you tried to evaluate current node's geometry in SOPs)
2. as mentioned before, you can't use .editableStage() and there is no need to as you can't and don't want to edit it
use .stage()
so your expression would be something like this:
use .stage()
lopNode = hou.pwd().inputs()[0] stage = lopNode.stage() print(stage)
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jsmack
- 7771 posts
ysysimonjsmackI want to read a attribute on a certain usd primitive to use in a channel,how should I do?
only the python lop has an editable stage. I think you just want stage?
Looking through the API documentation, using editableStage() seems to be the only way.
I would say don't. The USD python api is so opaque and arcane that simply getting an attribute value is an exercise in frustration. The objects that represent attributes and primvars don't themselves have methods for evaluation. The only way I've found to even evaluate a property is to use Sidefx' husd module for 'GetValue'. I still haven't found the Pixar way to get an attribute value. Keep in mind that referencing an attribute value could mean introducing a time dependency.
- antc
- 273 posts
Apologies if I'm misunderstanding, but the generic way to read an attribute is
and when possible, the recommended way is to utilize the schema that owns the attribute e.g
prim.GetAttribute("primvars:displayColor").Get(timecode)
from pxr import UsdGeom UsdGeom.Gprim(prim).GetDisplayColorAttr().Get(timecode)
Edited by antc - July 19, 2022 05:59:19
- Tim Crowson
- 240 posts
Yeah that's what I do (antc)... we have expressions that query attributes on USD prims this way and it's fine.
(Well technically the expression is triggering a python module on an HDA, but the same code works directly in an expression)
Edited by Tim Crowson - July 19, 2022 12:58:30
- Tim Crowson
Technical/CG Supervisor
- ysysimon
- 75 posts
antc
Apologies if I'm misunderstanding, but the generic way to read an attribute isprim.GetAttribute("primvars:displayColor").Get(timecode)
and when possible, the recommended way is to utilize the schema that owns the attribute e.gfrom pxr import UsdGeom UsdGeom.Gprim(prim).GetDisplayColorAttr().Get(timecode)
sorry I don't get it, how should I get the prim object?
And actually I want to get the local Transform, it's a Computed Value as I know, so I checked the USD API doc, but didn't find any way to get prim's GfTransform object.
- ysysimon
- 75 posts
Tim Crowson
that's means I don't need to get the stage to read the attribute?
- ysysimon
- 75 posts
tamte
use .stage()
so your expression would be something like this:lopNode = hou.pwd().inputs()[0] stage = lopNode.stage() print(stage)
ok, it worked, thank u, but is stage() means the stage it get from is read only?
- ysysimon
- 75 posts
jsmackysysimonjsmackI want to read a attribute on a certain usd primitive to use in a channel,how should I do?
Yeah, true, it's a new things just come out, not too much information about USD, but I think that's why we need to dive into it to give more information to the later.
Thanks for the reminder about time dependency, I've thought about it.
- tamte
- 8555 posts
ysysimoncorrect, you can't edit the stage using python unless you are in Python Script LOP
if every expression tried to edit the stage of any LOP node it would be a dependency nightmare
I thought you just need to sample the input stage for values or whatever that you want to compute your final expression value from
there is no other reason to use it in expression usually
if you need to directly modify the stage use Python Script LOP or Attribute Wrangle LOP or something similar
Edited by tamte - July 19, 2022 17:15:48
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- ysysimon
- 75 posts
- antc
- 273 posts
